judelaurenzo25g wrote:
can someone take a look at this charger and let me know if it will work for my situation.
Charger Here
Believe it or not... the Schus can actually do pretty well. I have the SC-8000A and it likes to get into the 15V range. That's pretty high for public consumption as you are getting into the realm of potential electronics cookery as well as gassing, i.e. Hindenburg "air."
Their amperage specs are B.S., though. Mine says "12-30A." And only IT gets to decide. So I consider it a 20A charger, at best. I found an Amazon review years back that seemed to confirm. I don't have a DC amp-probe, but one of these days I'll have to test it with the Kill-a-Watt to see how it acts.
For an auto charger, Mex's Black & Decker
VEC1093DBD cannot be beat... to 85% (though I think it does better than that.) I have the 25A version and love it. B&D acquired Vector years ago and rebadged their great chargers.
As stated before the equalize mode can get up to 16V... but only on a cold day. They're temp compensating... which is a good thing for safety.
But as Mex so eloquently eluded... these are designed by attorneys, with the general public's safety in mind. They are not up to the task of proper equalization. In fact, these are discontinued. The latest versions have dropped the equalization mode. I would bet at the behest of said attorneys.
My favorite for this purpose is my Harbor Freight beast. A few of us have them like Mena and Mex. Mex has lobotomized his and reported some stout components. And as far as the reviews go... he and I are in agreement. Most of the negatives are from people who don't know how to use them.
However, the ones HF is currently offering SAY "Manual," but don't appear to be well suited for equalizing. I found the following in the description...
"Switches to trickle mode when battery is completely charged"
I would think something like
this manual Schumacher would do the trick, but I cannot claim any experience with them. Ha! I just noticed that Amazon won't ship them to The People's Republic of Kalifornia. Maybe walmart or ebay will. A good ol' used manual charger probably wouldn't hurt.
Equalizing is not that hard, but there are definitely some tricks and important rules. It's a bit of a dance between breaking up sulfate and eroding the positive plates in the process. Done properly... and somewhat regularly, you should expect much greater lifespan.
I believe Mex has an equalizing tutorial around here somewhere.
As he said, you'll need a glass hydrometer. It's nice if it has a built-in thermometer. I just have a $5 O'Reilly's unit and I use my infra-red, laser thermometer. Your hydrometer readings should be temp adjusted to 77 degrees F (80 is close enough for us Yanks.) I use
this chart.Always wear eye and skin protection when working around batteries... especially while equalizing.
My process...
Disconnect from the coach first!
1. Charge fully to, say 14.5V.
2. Add equalizing charge to achieve some bubbling. 1/sec, give or take for maybe 20 minutes. Now your electrolyte should be stirred with little stratification.
3. Take a hydrometer reading and record with battery temp. Then make temp adjustments to readings.
If the float is in the white or worse... then I know I might be in for a bit of a haul. But I don't want to overheat nor erode the positive plates too much, so I do it in steps.
4. Equalize charge, i.e. voltage above 16 for an hour max to be safe (I go longer if I feel it's necessary, but I don't recommend it to newbs.) Always monitor battery temperature!
A 10A, Manual Schumacher might take some time to get from "full" to over 16V. So... unless it's a hot day... I would not start counting the hour until you reach at least 16V.
Now this is a little controversial. To do it 100% correct, you should let the batteries sit for a day while all the fizz and cloudiness fades. But I say... yeah, your hydrometer readings may be off a bit due to fizz, but we're about to compare apples to apples. So... in order to save time...
5. Let them set for 20 minutes or more and take another hydrometer reading and adjust for temperature... which might be higher now.
6. I keep repeating this process until the temp-adjusted readings no longer climb. If you keep the same resting interval between stopping the charge and taking the readings... then the fizz amount should be fairly comparable, i.e. apples to apples.
7. Let your batteries rest for at least a day before hooking them back up to the coach. Ideally take a sample and make sure it's clear before using them again.
Disclaimer: This is just my opinion. I'm not an expert. You would be wise to do your own research, yada yada yada.
