BFL13
Jun 10, 2018Explorer II
"I charged -- then disconnected the battery last fall -- in April it was still very close to 13 volts, so it held it's charge well over winter. I'm wondering if I have a short somewhere in the camper that is sucking the battery down?"
It "held its charge" with no load on it, but collapses under a load. Usually means the battery is sulphated, as noted above re previous undercharging.
It is still possible there is an unknown draw in the camper. Your Happijac problem might be related. Is it possible for the jacks' power unit to be stuck "on" when you think it is turned off?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
