SoundGuy
Jun 11, 2018Explorer
Old Islander wrote:
We have a 2-way fridge with tiny indicator lights only. No light in storage area. Water pump is tight -- might run for a second or two, every 4 or 5 hours. Not sure what the emergency brake pin is? This is a slide-in camper on a truck.
What make / model of fridge? Does it have a climate control heating element and if so have you ensured it's turned off, for if not it will significantly draw down your battery reserve. You also need to ensure that any other parasitic draws are turned off, in some cases requiring you to install kill switches, such as in a stereo. Obviously, as a truck camper there won't be any brake system break away switch - but that wouldn't have been mentioned if you'd told us this was a TC. :R
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
