time2roll
Jun 20, 2018Nomad
Fully charged at home? Did you verify with a hydrometer?
I think you may need an equalization charge.
What converter model does the TC have? Have you checked that it charges at 14.2+ volts on the battery at some point?
I suspect you may have a fixed voltage trickle charge that will chronically undercharge the battery. Also extends the run time for the Honda to charge.
100 to 200+ watts solar will certainly make a difference if you are parked in the sun. Can also make up for a poor converter.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
