dougrainer
Jul 08, 2013Nomad
BFL13 wrote:
You have a 35 amp converter trying to go through a 20 amp fuse. change it to a 40 amp fuse. Somebody at the factory was an idiot ( not unusual sadly :( )
This is NOT the cause. You are confusing Power Converter AMP rating with actual charge amps. The charge amps is NOT 35 amps.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
