beemerphile1
Jul 08, 2013Explorer
dougrainer wrote:BFL13 wrote:
You have a 35 amp converter trying to go through a 20 amp fuse. change it to a 40 amp fuse. Somebody at the factory was an idiot ( not unusual sadly :( )
This is NOT the cause. You are confusing Power Converter AMP rating with actual charge amps. The charge amps is NOT 35 amps.
:h The 35 in the model number 8735 means the converter has the capability to put out 35 amp +/-.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
