brulaz
May 11, 2014Explorer
Almot wrote:
On-battery fuse by Bluesea is the easiest and closest to battery. Not cheap. Check Amazon, I think I paid $25 for a single block and $18 for a fuse. You don't need a double block if this is only for a battery fuse.
Yes, that's what I linked to in the first post. So guess everybody has had a good experience with it. A bit expensive though ... the wiring, cables, breakers, breaker box, and fuses are getting to be as expensive as the solar panels.
EDIT: westend's solution is a lot cheaper though. But I can't find a 60A version. The 60A equivalents come as MIDI fuse which are smaller and use a fuse holder, not bolt on.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
