NinerBikes
Sep 27, 2014Explorer
Mex, as far as my Megawatt version...FWIW, if I drop the voltage from 14.8 to 14.4 at start up, the MW does drop the amps it provides to my T 1275. Maybe you want to install a volt meter on your chinesium, plug it in and start the voltage low, and then slowly adjust voltage upwards, to control the amp flows.
Don't exaggerate about needing a screw gun. If you start the volts low,the amps will be low also. Keep your ears in tune for the buzzing sound and don't make it buzz, and you should be good. Or water that money tree and buy meanwells next time.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
