MEXICOWANDERER
Sep 27, 2014Explorer
Respironics 5.11 amperes @ 12.04 volts.
The GPL-31T is designed for charging amperages up to 262.5 amps or 250% of the rated Amp Hour Capacity due to low battery internal resistance.
If this came from Concorde battery they are contradicting themselves. The user manual recommended by Corcorde last week clearly states the battery can accept a 500 ampere charge rate and return from a 95% discharge (5% remaining) in less than an hour.
Document 6-0101 Revision D (2014)
Regardless, the battery is going to ultimately be fed with a mere 120 amperes. And I will increase charge lead size to 12AWG to throttle current proportionate to the charger's wattage potential limit.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
