JoeH's avatar
JoeH
Explorer III
May 02, 2013
Battery hints/tips
Awhile back I recall seeing a topic on battery maintenance.... including things such as additives, mineral oil use, automatic watering setups, etc. I did a search and can't seem to find it.
We just got a new MH and I want to see what some thoughts are on proper maintnenace and tips for flooded batteries to keep them going as long as possible.
  • smkettner wrote:
    First review your charging system. Including how do you keep the chassis battery charged.
    x2 and really depends on your specific use profile, so you could get a lot of different opinions on this depending on what others think your needs are. For example if you have the typical 4 6volt house battery with dual 12 volt starting batteries and the coach sits in unpowered storage a lot then:
    100 watt solar panel with a morningstar sunsaver duo controller will keep both your house and starting batteries in tip top condition all the time. Costs about $150 for the panel, $100 for the controller and $50 in wire/stuff. $300 and you have a hands off fully automatic battery maintence system that will keep the batteries good for years (like 8 to 10 for most people)
  • A lot of that sort of thing is just snake oil and old wives' tales.
    If you really care, then please specify whether you will be on shore power all/most of the time or off grid recharging by solar and/or gen-charger most of the time. It is all "situational" what works best.
  • First review your charging system. Including how do you keep the chassis battery charged.
  • Check out the June, 2013, issue of MotorHome magazine. It has a detailed article on battery maintenance.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
