BTPO1
Aug 26, 2014Explorer
Old-Biscuit wrote:
Always connect positive cable 1st.....then ground cable.
Reverse when disconnecting.
AND..follow that white cable and check that it is attached to trailer frame (ground)....nothing standard with trailer mfg. cable colors :S
I agree with Old Biscuit on this one. You should always follow the cable and see where it goes. You can't go wrong if you trace the cable to it's source. JMO
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
