LittleBill
Mar 21, 2021Explorer
otrfun wrote:
Got a reply back from the seller of the $85 KeyLine Battery Isolator about its parasitic current. Their reply: "Yes, it is always monitoring and takes .02 Amps to do so." 20ma is more than acceptable for our application.
FWIW, there's a number of battery isolators on Amazon that look eerily similar to the KeyLine, have the same dimensions (2.6 x 2.6 x 2), voltage cut out/in (12.8v/13.3v) and amperage specs (140a) as the KeyLine, but cost significantly less (one was only $27).
add a toggle switch on the ground and you will get it down to 0. Be aware you won't get emergency start from this,
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
