Makin__Do
Mar 14, 2016Explorer
Battery Isolator
Posted a question two weeks ago about the possibility of running an inverter off of the battery isolator. Not such a good idea. I'll go to solar to keep my batteries topped off while I'm driving.
While checking out the isolator, I discovered the isolator output voltage to the house battery was 15.4 - 15.8, way too high as reported by several of you. Replaced the isolator with a new Sure Power model 702. Output from the isolator was 15.3 - 15.5. Still too high. So, what I did was (perhaps not the best solution) put an old voltage regulator in the line and the output is now 14.3. - 14.5.
I'm not so sure I like this solution. Is there a better way of getting the voltage down?
