wolfe10
Feb 11, 2023Explorer
jjrbus wrote:
My 94 Toyota had the old fashioned Cole Herse isolator, looked like a Ford stater solenoid. I added a switch to connect the house side to the vehicle battery and turned it on when on shore power. Can I add a simple switch and wires to this isolator to connect batteries when on shore power?
Yes, you can add a solenoid-- common on most rigs and referred to as a battery boost or battery combine solenoid.
Be sure you get a CONSTANT DUTY solenoid rated at least 25% more than the max amp load it will be seeing.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
