Gjac
Feb 12, 2023Explorer III
jjrbus wrote:This is one way that is simple, another way that you probably have built into your chassis already, is to turn your key to ACC and that should combine both batteries. While plugged into shore power check both batteries to see if you get 13 plus volts.
I do not understand why I would add a solenoid? Wouldn't I add a wire between the 2 battery terminals on the isolator with an inline 12 volt
switch??
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
