monkey44
Jul 24, 2017Nomad II
Battery isolator?
I've had three isolators fail - two replaced via warranty - but again, a fail. So, I had to bypass it to get Lance Truck Camper battery charging on the road to get ourselves home last trip.
Now, when I shut the battery disconnect, it shuts down battery power to the camper, but if I leave the connector wire to the truck, it draws power from the truck battery. SO, I can't leave it, obviously.
ANyone recommend a good quality isolator that will stop the truck battery drain while camping, but just allow charging on the road. I'd prefer not to install a disconnect switch, which is practical, but then manual, which it OK with me anyway.
What benefit does the isolator actually give us, when installed? Other than separating the two batteries from the charge drain??? Thx M44
