Hello, I am new to this forum. I have a problem that I cannot figure out and need some advice. I have a 2007 Springdale rv 30'TT. Sort of a long story but I want to give the whole story. After I ...
You need to determine the output of your converter to see if it will fry the battery. Disconnect the battery (take both battery cables off of the battery), plug the TT in, read the output voltage of the converter at the battery cables. Should be something like 13.5 to 14 volts. If its to high it will fry the battery (not sure how high it can be without damaging the battery). If it's too high you have to replace the converter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
