djbadcat
May 05, 2015Explorer
Battery Issue
Hello, I am new to this forum. I have a problem that I cannot figure out and need some advice. I have a 2007 Springdale rv 30'TT. Sort of a long story but I want to give the whole story. After I ...
grizzzman wrote:djbadcat wrote:
Yes I do have a trickle charger. That crossed my mind as well. I checked the battery terminals with the multimeter, as it was cycling on and off was 12v off and 14v on.
As for the circuit breaker, wouldn't it trip once then I would have to manually reset it?
Thanks again for the info.
Dan
The circuit breaker is self reseting. 14 volts means that the converter is in bulk mode (due to the low battery) Put your trickle charger on it for several days then plug it in. If no noises. I would then investigate the circuit breaker. Before you charge it,try to find the circuit breaker using the clicking noise. Its VERY likey that it needs to be replaced. Its a small rectangular metal box with two wires. It is likely that it is a WFCO 55 amp converter and the breaker is 30 amp. If this is the case find at least a 50 amp (60 would be better) breaker and replace it.
