Michealbraunste's avatar
Nov 13, 2018
Battery Issues
Hi All,
I have noticed that the battery on our 19 doesn't have the capacity it used to have. When the sun is hidden the voltage drops more quickly than it used to. Under load, the voltage drops further than it used to. So we'll probably replace the battery next spring. I've read through a bunch of forum posts. I think I will go with an AGM battery so I am planning to order one from trailer parts online given that we are frequently offshore power and sometimes push our battery maybe further than we should. But which one? Have you bought an AGM battery in Canada? Are the Canadian Tire MotoMaster batteries ok? Is there a better alternative that I've missed?
  • A pair of 6V golf cart batteries are still the "best bang for the buck". Trojan does make an AGM golf cart battery (T105-AGM) but they are expensive.
  • Sounds like you are not getting a full charge on the batteries, you may need a bigger charger to handle the load and beable to resyore the batteries charge.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 05, 2025
