path1's avatar
path1
Battery jumper cables and terminolgy of CCA
How bad did I mess up? Was at Harbor Freight picking up some 6 ton jackstands and saw what I thought was OK deal on jumper cables. Picked up 16 feet 6 gauge "heavy duty steel clamps, cooper jaws, cca wire" Some things I obviously wrongly assume a manufacture can't mess up.
After getting them home and looking at them outside of box I thought no way these are 6 gauge. Then I learned the "cca" was the type of wire and not what I was thinking as Cold Cranking Amps. Found out CCA is actually a cheaply coated alum wire. But then again I'm not going to jump a bank golf cart batteries.
My other jumper cables that I keep in pick up are about the same weight and only 1/2 as long.
Question: Are these OK for normal battery jump stuff to keep in RV or totally junk?
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
