acker1's avatar
acker1
Battery load tester?
Anyone have experience with these? Best ones for a reasonable price?
Thanks
DICK
  • I had a deflated battery that couldn't catch it's breath but a good swift kick in the butt cured THAT
  • Son of Norway wrote:
    I got one at Advance. I use it frequently to check the health of some of my lead acid batteries. But it's only one aspect. A battery can be severely depleted on overall capacity yet still test well on a load tester.
    Miles
    Never had a depleted bad battery test good on load test
    you put a proper test using the specs for that battery's rated capacity
    it will NOT test good if it can't carry the amps for the full TIME DURATION
    a battery with an internal leakage, can carry full amps when tested at full charge, but still loose charge from the leakage
    load capacity is just ONE test
    holding voltage at rest is another test
    as is reading the SG of Flooded cells
    i have the Harbor Freight 500amp carbon pile tester
    also available online under other brand names, same tester
    it has been very useful, i'm happy with it
  • Quote:
    Wow, after 50 yrs of testing batteries, I learned something new:R
  • I got one at Advance. I use it frequently to check the health of some of my lead acid batteries. But it's only one aspect. A battery can be severely depleted on overall capacity yet still test well on a load tester.
    Miles
  • Look on amazon tons of them just depends don't buy a cheap one you get what you pay for.
    You can always just take the batts to auto parts store they can do for free
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
