MEXICOWANDERER
Jul 05, 2015Explorer
NO storage battery on the face of the earth should be left unattended unless it has monitoring and alarm devices. One battery and one float charger can raise just as much hell as four (not fourteen or four hundred) floating batteries. Four is about my personal limit as percentages start to get too high to expect one battery in the lot to fail.
As far as multiple batteries charging on the same string I have 24. If the flat voltage value is acceltae to the battery it doesn't make a bit of differene if one or a bundted batteries are on line. Greening rooms typically have more than two hundred batteries onj
Ine.
Ine.
