beemerphile1
Sep 15, 2013Explorer
rexlion wrote:
...some people feel the WFCO will not do a very good job and may cook the battery.
I think you misunderstood. Some have complained that the WFCO will struggle to achieve boost mode when drycamping and charging from a generator. It is a three stage 'smart' charger and will do an excellent job of maintaining your battery.
rexlion wrote:
...Will the BatteryMINDer and/or the Battery Tender yield significantly better battery performance than the WFCO? Than the HF float charger? Or is there an even better way? TIA.
Nope, the Deltran Battery Tender and the Battery MINDer are both three stage smart chargers and any differences are minimal. The HF float charger is a constant single stage charger and shouldn't be left on indefinitely. The BT and BM do have a couple advantages but if you have no other use for them, stick with the WFCO.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
