jgrimes's avatar
jgrimes
Battery Minder
While gone for an extended time, I plan to keep my car battery charged at home using a Battery Charger Junior. Do I need to disconnect the battery from the auto while charging; or can I charge without concern for damaging the auto's electronics? Thanks in advance.
  • If the time is 3 months or less, just disconnect the battery - no minder needed.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    ScottG wrote:
    You can leave it connected.
    L left mine connected no problems.
  • If leaving for more than a month I recommend that the Battery Minder not be plugged into a GFI receptacle.
    I had done that for 6 months a found a totally dead and ruined battery because the GFI had tripped.
    Possibly due to a power surge or power outage.
    X2. we do this all the time.
    Not only can but probably SHOULD.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 01, 2025
