SJ-Chris's avatar
SJ-Chris
Explorer II
Sep 24, 2017
Battery not charging (from chassis or generator)
Hi All, new to RVing. Thanks in advance for you help!
I've got a 2006 Four Winds Chateau 31p Class C with a Ford Superduty e450. RV has an Onan 4000 generator. I've got a 12V deep cycle house battery along with two 6V golf cart batteries for a total of ~350 amp hours of house batteries. The two 6V batteries are wired in series to equal 12V and they are then wired in parallel with the 12V battery. The 12V battery is brand new. The two golf cart batteries are 2 years old.
I'm having an issue with the house batteries not charging. I have a battery reading in the RV which isn't too accurate (it just shows 12V / 11V / 10V). Right now it is showing 11V. I thought it would be better to use a volt meter to be more certain.
I put a volt meter on the house batteries and they currently read 11.75V with nothing on (the generator is off and the chassis engine is off). If I disconnect the battery and measure the battery itself it reads 11.75V. The chassis/engine battery is at 12.29V (with everything off).
When I start the chassis engine I would expect the alternator to kick in and charge both the chassis battery and the house batteries. When I turn on the chassis engine I read the chassis battery and it shows 14.34V (which seems good and what I would expect...the alternator seems to be working). When I check the house batteries (with just the chassis engine running) I would expect to see them charging. But I don't...they remain at 11.75V. I measured the house battery terminals while connected to the battery (11.75V). As a test, in case maybe the house batteries are dead/etc, while the chassis engine is running I disconnected the house batteries and put a volt meter on the wires that would be connected to the batteries and the voltage on them was also 11.75V. That seems to tell me that the chassis alternator is not charging the house batteries.
Question: Shouldn't the chassis engine being charging the coach batteries? Are there any fuses/etc I should be measuring to pinpoint what the problem might be?
I turned off the chassis engine. The next thing I did was turn on the generator to see if it would charge the house batteries. With the generator running I measured the voltage across the house batteries, expecting to see them charging. The voltage was 11.71V. Ugh! With the generator running I measured the voltage of the chassis battery and it reads 12.73V. I tried running the generator with the 12V battery disconnected with only the 6V batteries (same result). I tried running the generator with the two 6V batteries disconnected and only the 12V house battery (same result).
Question: What voltage should I see across the house battery when the generator is running? Is it common for the generator to also charge the chassis battery?
Are there any fuses I should be checking?
What should I check next? Any ideas?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
