pbeverlyNomad IIMar 03, 2022Battery On/Off SwitchI am going to install a battery on/off switch on a TT. Where would you put the actual switch? A lot of pictures I have seen they are on the plastic case the battery sits in.
QCManNomad IIIMar 03, 2022The closest you can get to the battery the better. No reason to have to make long runs of heavy gauge wire.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Switching toiletsadding on/off toggle switchAutimatic Transfer Switch?Battery Disconnect switch/charging - ON OR OFF?
