Duck's avatar
Duck
Battery Parasite Draw or Normal
I keep my trailer in a storage lot that does not provide electricity. I keep the battery disconnect switch in the off position. I will measure the voltage on the batteries and for example will show 12.5 volts. Go back two weeks later and they measure 12.4. Is this normal or do I have something drawing a little on the batteries.
Don
  • Deep cycle batteries self discharge at some place around 5% to 20% per month, more for those reaching the end of their life. The only way to find if you have a vampire load is use an ammeter and the way to assure you do not, is to disconnect the negative terminal from the battery.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
