theoldwizard1
Dec 30, 2018Explorer II
When using L-terminal or stud (NEVER use wing nuts) batteries I like to use stainless steel bolts, washers and nuts. Almost corrosion proof, but I still apply a good "gob" of grease (silicon dielectric or Vaseline or axle/bearing grease in a pinch) on top of the connect, covering the area where the metal connection comes through the plastic case. t make not look pretty, but it is cheap and effective insurance !
Fluid Film spray of Lanolin spray work well and "look" better, but need to be cleaned and reapplied every year or two.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
