theoldwizard1
Jul 10, 2017Explorer II
beemerphile1 wrote:
Impact Driver is used for running screws.
Impact Wrench is used for lug nuts.
A drill is all that is needed for the stab jacks.
CONCUR !
If you are carrying a torque wrench for the finally tightening of wheel lug nuts and are willing to use it to crack them loose, then you can save yourself a lot of money be buying a 3/8" drive 12V impact wrench like a Milwaukee M12 3/8" impact and 3/8" drill/driver. Save even more buy choosing the non-FUEL versions (FUEL version have a bit more power and a bit better battery life). Stick with the 3/8" impact NOT the 1/4" hex, then buy a Milwaukee 48-03-4405 square to hex adapter.
If you want to do lug nuts, you really need an 18V (or higher) 1/2" impact.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
