wealthwise's avatar
wealthwise
Battery Problem
I have a problem with a starter battery at least I believe it's a starter battery. It shows cold cranking amps so it's got to be a starter battery, it's connected to another battery that's fully charged over 12 volts. I had to add distilled water to the cells I"m not sure if they could be bad, I tried charging it in regular and trickle but I couldn't get past 12.70 volts, last night It was at 12.55 and today it's at 12.12, could this battery be bad? I don't have a hydrometer to test it, do you think it needs to be replaced? Being that's a starter shouldn't it recharge with the alternator or is it controlled by the isolator?
Thanks for any help.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
