MEXICOWANDERER
Jan 14, 2015Explorer
You'll hear a dozen different reasons why keeping them together or separated is better. Seldom is the most pertinent reason to parallel them mentioned..
You have a charger or charging system. When you enable the charger a monster fuel eater starts up. Here is an exaggeration It gets the point across.
Let's say one 6 cell battery drops to a 12 amp charge rate rather than a 35 amp charge rate during the peak of it's hunger. Running a generator to get a piddly 12-amps is horrible to think about, right?
But what would happen if there were four batteries instead of one?
48-amps is not so piddly, is it? And an amp hour is an amp hour no matter which way the bread is sliced.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
