towpro
Mar 10, 2015Explorer
smkettner wrote:
When you get the RV and batteries together give a post what brand and model converter it has. Also need to dig up Cabela's charging specs. Definitely need to have three stage charging. Bit of solar would also help but now the budget is busted. Once you have a plan you can fill in as needed.
An option could be a battery A-B switch than run each battery one at a time. I was planning on maintaining the batteries with an external charger I have between trips (but its only 15 amp smart charger so I see I need to look into that).
and the budget does include some solar some time in future, but first is the batteries and a Bogart TM2030.
We will see what kind of charger the Wolf Creek has in it. I have a feeling my Open Range 5th wheel is going to need a charger soon (it was acting up last year), so maybe the one from the Wolf Creek might move to the 5th wheel when its time.
and I will look for the bible on the lifeline batteries. Thanks
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
