Grit_dog
Mar 15, 2023Trailblazer
It’ll work for what you’re using it for, which is virtually nothing. It’ll also probably not last long since on in the pair already died (unless it lived an unusually short life for some reason).
The reason “not” to use start batteries in general is they don’t handle deeper discharges as well and if used like a typical deep cycle, won’t last near as long. Nothing else fundamentally incorrect about using it.
Just like deep cycles generally can’t handle the peak amp draws of a start battery when cranking a large engine over.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
