Jun 13, 2022Explorer II
You have the correct batteries for the charger.
The ELECHG1024 has gone through some evolution. The earlier version was A24030-9C. It was upgraded to the A24030-10C, which you have, then upgraded again to the currently available A24030-10D.
I was unable to find details on your -10C. I did discover the -9C should output 29.7V, which is 14.4V per battery. As mentioned above, your meter could very easily be off by that much, which is 1%.
Use it to put it through a few cycles and contact Pride if you still have a concern.
