Ok, this is embarrassing, but I have to ask. This is out first 5th wheel without a generator. So please bare with me. How can I run my TV or other small appilances off the batteries? That is if it ...
Most modern TV's only run on 12 volts. If there is a little power pack, called a wall wart, that plugs into the 120 volt receptacle, look at it close. Most likely it will say 12 volt dc output, and the other end plugs into the TV. Just find, or build a cord that has a 12 volt cigarette lighter plug on one end and will plug into your TV with the other end.
Dusty
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 06, 2026
