This may be a stupid question, but here we go. If I have a battery that doesn't charge, would that stop the lights in my camper from working. Thanks in advance for the help.
If you're not getting any 12V while plugged in, it's a problem with the converter. And, your battery is drained. As soon as you can, get a charger on the battery. If you're lucky, you can save it. The longer it sits "dead," the more likely it will be ruined. With the charger connected and on, you should also get lights.
Then, worry about getting the converter fixed/replaced.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
