red31 wrote:
uintafly wrote:
has a 2, 10 or 15 amp option and I don't know what to choose. Anyone know what exactly this option refers too? Does it even matter when it's just on the maintain function?
Thanks for advice
Automatic charger.
This option is for the initial charge rate of either 2,10 or 15 amps.
Once the batts get to 14.?v, the current declines as the batts are held at 14.?v. When the current is low enough the charger becomes a maintainer at 13.?v.
I wondered it this was probably the case.
I also purchased a multimeter on Saturday and have taken some measurements. On Saturday night both batteries were reading at 13.4 volts. On Sunday afternoon I took a measurement with the charger on and it showed 13.85. I turned off the charge and waited a minute or so and it dropped to 13.5. I kept it off and measured about 2 hours later and they both had dropped to 13.2. As of this morning they were both still at 13.2 volts. Does this seem normal? Earlier in the thread someone mentioned to make sure they stayed between 13.2-13.5, but they are definitely over that with the maintainer on.
Also, a few mentioned to just use the 30 amp from the trailer, but where I keep it parked in the winter would require me to run a 50 ft. extension cord to keep it plugged in.
Thanks again
