BFL13's avatar
BFL13
Explorer II
Mar 26, 2021
Battery Rating vs Capacity Monitoring
Some things:
Shipping batteries in the US requires the Watt-Hour rating to be marked on the battery, and the rule is to use the "nominal" voltage. So LFP uses their 12.8v figure for that 100AH x 12.8 is 1280 Wh
I think ? the "nominal" voltage for other batteries is 12v and 6v, eg so a 100AH 12v would be 1200 Wh for shipping it.
This has nothing to do with their capacities you want to monitor in an RV, where you start with the capacity as Full (100%) and you have voltage tables vs SOC as percentages of capacity. Using AH for capacity:
The AH rating is at the 20 hour rate, which has the batt run down to 10.5 volts. A battery is not out of all capacity below the 10.5v, but the SOC tables use "residual capacity" at 0% at different voltage levels
Battery type, !00%, and 0%
LFP- 13.6, 10
SiO2- 13, 11.1
AGM -13, 11.5
FLA- 12.73, 10.5 (Trojan table only goes down to 10% at 11.51)
Not clear how the 20 hr rate down to 10.5v works for an LFP that has zero at 10v or an AGM that has zero at 11.5v.
You do have to enter something in your SOC monitor as what 100% is in AH and have an idea what your battery's voltage/SOC numbers are, as they are all over the map by battery type.
LFP also have a BMS to make it interesting.
  • Anybody understand this? Converting the v/SOC tables to Wh from 100% and 10% to get the Wh used for 90% SOC = 90AH (all 100AH batts)\
    10% SOC is:
    LFP -12.1v so 10AH x 12.1v = 121 Wh from 1360 = 1239 Wh is 90AH
    SiO2- 11.46v x 10 = 114.6 from 1300 = 1185.4 Wh is 90AH
    AGM-11.75v x 10 = 117.5 from 1300.0 = 1182.5 Wh is 90AH
    FLA- 11.51v x10 = 115.1 from 1273.0 = 1157.9 Wh is 90AH
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
