Kober
Nov 28, 2017Explorer
Battery recommendation
My new to me toy hauler came with only one battery. I plan to add a second battery and am looking for recommendations based on your experience.
time2roll wrote:Kober wrote:If you expect a semi-fast recharge using a generator you will probably need to upgrade the WFCO.
I looked and it is indeed a WFCO converter.
Give it a try charging a lowish battery and see if voltage steadily climbs to 14.2+ volts and you are good. Most WFCO just trickle charge at 13.6 volts max regardless of what the battery needs. There are few tricks to get boost mode but most give up and replace the converter.
