Kober
Nov 28, 2017Explorer
Battery recommendation
My new to me toy hauler came with only one battery.  I plan to add a second battery and am looking for recommendations based on your experience.
Kober wrote:MEXICOWANDERER wrote:
No pedestal hookups? A not-connected while parked at Times Square is no different than not-connected at Quartzite.
Perhaps I misunderstand your conceptualization of a "campground"
I expect to be hooked to shore power at RV parks (and water) for most of our longer duration trips, or be running the generator. Only expect to be using battery power during quiet hours at RV parks or whenever we don't need AC for TV, MW, etc.
2oldman wrote:Kober wrote:That'll do it.
... and 2 Honda gens to keep the single battery charged. .
Ductape wrote:
"New to me" implies a used battery. Two different age batteries in parallel is recipe to ruin both when first one goes. Spend a bit more and get two 6v golf cart batteries.
time2roll wrote:Kober wrote:If you expect a semi-fast recharge using a generator you will probably need to upgrade the WFCO.
I looked and it is indeed a WFCO converter.
Give it a try charging a lowish battery and see if voltage steadily climbs to 14.2+ volts and you are good. Most WFCO just trickle charge at 13.6 volts max regardless of what the battery needs. There are few tricks to get boost mode but most give up and replace the converter.
OK, but while others have chimed in, IMHO WE need more information on YOUR planned camping to give any valid recomendations.
So....
Will you be dry camping? If so, how often and how long. And when dry camping what do you want to do? watch TV, run a microwave? camp in cold weather?
How many day/year would you dry camp?
If you don't dry camp, and go with full hookups, how often? and when you are at rest stops do you want to run a microwave?
If you will dry camp and camp with hookups, how how many days/year of each and how many days at a time.
With this info WE have a better understanding of YOUR needs and can better advize you on what to do about batteries.
What works for me may be entirely in approriate for you.
How do you plan to use your unit?
