Dernhelm's avatar
Dernhelm
Battery Replacement Problem
So some &^%$#@! stole my battery by chopping the cables and carrying it off. Little did he know that it was already 3 years old and it gets HOT here soooooo.... it was probably dead anyway. However, that's not the problem.
I had a friend splice on new cables and connectors to the nice new battery in the nice new locking battery box. I made VERY sure he used the same cable gauge, but now my trailer brakes are screwy. They over-brake and I had to turn them WAY down.
Is this a resistance problem from the splicing? Did the friend lie about the wire gauge and it actually doesn't match? Do I need to spend an arm and a leg having the battery cables professionally replaced end-to-end?
Thanks for advice!
  • The battery was stolen off your truck or camper?
    I read it as off camper. Doesn't your brake electric come off your truck through the 7 way plug?
  • My guess is you are just observing the difference between an older battery with older connections to a new battery with nice clean connections, and you are getting better voltage to the brakes. If they work properly when you turn them down, there shouldn't be a problem ...
    Guess you showed them! Of course, you probably will owe them some money on the pro-rated age of the battery!:B
    As for the cables....unless they were done incorrectly, you shouldn't have a problem with a properly spliced set of wires.
    No real idea why you are having issues with the brakes?? Sorry.
    Good luck
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
