2oldman
Mar 17, 2014Explorer II
It won't matter to the converter as long as the configuration is 12v. It'll just take longer to charge. The only way I would consider it part of the design process is if it's a low-amperage unit (say, 20amps) which will make recharging with a generator a long process.
By the way, 3.5 years is a relatively early death. What happened? You said you primarily camp with hookups, so does that mean your converter is overcharging and killing them? Are they low on water?
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
