pianotuna
Mar 17, 2014Nomad III
Hi,
No meaningful answer can be made without knowing the make and model of the converter in your RV. If it is a modern three stage converter, you will be fine. If not, then consider upgrading.
If you plan on a large inverter then twin twelve volts wired in a balanced manner may be a better choice.
If it is a small inverter and you do lots of camping with no hook ups then twin six volts may be a better choice.
If you nearly always camp with hookups then expanding capacity is not necessary.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
