Gjac's avatar
Gjac
Explorer III
Jan 20, 2015
Battery Self Discharge
Would the rate at which a battery self discharges be a way of determining the health of a battery? I have (2) 7 year old Sam's Club GC batteries that have been sitting without charge(battery disconnect switch on) since Nov 4 2014. On Jan 10 2015 they read 12.48 V at 20 degrees F. I know a load test would be the normal test, but I am in Fla now and the MH is in Ct. So is there a direct correlation between the rate of self discharge and how many more years a battery would last assuming the same usage as the previous years?
  • Not really. It has been my experience that the real killer for most lead acid batteries is shorting between the plates in the battery. It's cause by either warped plates that short or by solids in the acid that short across the plates.
    Another cause for failure in non-sealed batteries is low acid levels that allow the plates to be exposed to air and oxidize.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 29, 2025
