ktmrfs
Mar 09, 2021Explorer III
for fusing a battery you need to consider two things
1) max draw that you want to allow (when the fuse will blow or breaker trip)
2) max circuit interupt the fuse/breaker can handle. you want a fuse that will blow at say 200A but will not sustain the 1000A or so the battery can supply via a continuous arc across the open fuse.
Fuses that can handle that type of load are usually larger than the typical fuse and sand filled to extinquish the arc. And some have fuseholder that can be mounted directly to battery terminals.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
