SJ-Chris
Mar 09, 2021Explorer II
I've got 3 coach batteries. Do you see anything wrong with something like these (but at 350 amps each):
https://www.amazon.com/dp/B082NK8QVF/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B082NK8QVF&pd_rd_w=81Z5o&pf_rd_p=4269e1a0-a218-4fbd-9748-1cd337d2f2a5&pd_rd_wg=FPLSN&pf_rd_r=RTZPRBVZR311ZN532255&pd_rd_r=a3a69d18-d068-4c4c-94ef-f2da5f9c8f13&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyWTlJQkVUODY4MzA0JmVuY3J5cHRlZElkPUEwNzQ0ODM3MUxTVFJVWEowQUZZRSZlbmNyeXB0ZWRBZElkPUEwNTA1OTk4REo3QUpEV1lKMlBKJndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
I figure with 350 amps each, if I need to use the Emergency Start switch to jump start the engine (if the chassis battery is dead), the draw will come roughly (except for some imbalance in wire lengths) 1/3 from each of my coach batteries. 350x3 = 1050 cranking amps....should be more than enough I'm hoping. I'll disconnect my chassis battery and try starting the engine and see if any of them blow and report back.
-Chris
-Chris
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
