SJ-Chris
Mar 09, 2021Explorer II
Chris,
Unless I am misreading your link, max wire size for those fuses is 1/0.
That certainly would not handle high amp start loads or high amp inverter use if that is what you contemplate.
Regarding wiring gauge for "Emergency Start" situations (jumpstarting the engine with the coach battery(s) when the chassis battery is dead):
When I google "what is standard car battery cable gauge" the answer that comes back is 4 AWG wire.
I do find this interesting because when you think about the engine starting and the Cold Cranking Amps for example being in the 500-1000amp range on most batteries. It seems like 4 AWG cables (in the engine compartment connecting to the chassis battery for startup) aren't thick enough. So it must be that the DURATION of the draw is very low such that the wires can handle it, right?
If I look at my 2015 Thor Majestic 28a, and I look at the cable that goes from the battery isolator solenoid in the engine compartment back to the house batteries (so that the chassis alternator can charge the batteries while driving), I see that it looks like it is a standard looking battery cable (probably ~4 AWG...not really sure, but it doesn't look particularly thick). This would be fine for the alternator charging the house batteries since that should probably max out at about 75amps (maybe 100amps at the most). BUT...most Class C RVs also use this battery isolator solenoid with an "Emergency Start" switch that allows you to temporarily connect the chassis battery to the house batteries in the event your chassis battery is dead and you need to jump start the engine with the house batteries. In that case, there could be 500-1000 Cranking amps coming from the house battery(s) to the engine starter during engine startup. If that wire wasn't large enough to handle that, I don't think Thor (or any other Class C manufacturer) would use that thickness of wire. So it must be okay. Again, it must have to do with the short duration of that heavy draw.
What do you think? (I'm no expert, but I'm expecting the RV manufacturers to be smart enough to get it right).
Regarding wiring gauge for inverter use:
I have 3 batteries in my battery bank. So the power draw from each will be roughly 1/3 of the total. They are hooked up "Method 3" style (although with varying lengths which was pretty much unavoidable). From the point where all the positive (and negative) cables come together, there are 2 parallel sets of cables that are 2/0 in size running to my inverter. So let's assume my inverter is drawing 100amps from the 12v batteries. Each battery will be supplying roughly 33amps (through a size 2/0 cable) to a common point, and then 100amps will be flowing to the inverter through two 2/0 cables (2 for positive and 2 for negative...so roughly 50amps per wire).
According to a voltage drop calculator, the 33amps running 10' on a 2/0 cable will have a .4% drop (about 0.05v of 12.6v) which is very good I think. The 50amps running ~8' through each of the wires to the inverter will have a drop of ~0.56% (about 0.07v of 12.6v). So my total voltage drop during the inverter drawing 100amps will only be ~0.12v. That's good right? I felt like doubling up on the wiring from my inverter to the batteries was being pretty conservative and would be helpful.
Let me know your thoughts.
-Chris
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
