wa8yxm
Jun 11, 2013Explorer III
It may just be the power path in your RV
For example, in my "House" the batteries are up front under the steps.
The converter as far back as possible and on the other side
The fuse block perhaps 10 feet from the converter and 30-40 (Wire run wise) from the batteries.. The monitor is hooked to the fuse block.
So if I have lights or fans or other 12 volt eaters on there is voltage drop to the fuse block with the batteries alone, dang little with the converter.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
