dclark1946
Apr 15, 2015Explorer
MEXICOWANDERER wrote:
Your meter showing state-of-charge could be off-it's-rocker.
Use a hydrometer to see where the batteries are really at charge wise. Meters are as reliable as using a Fortune Teller. A hydrometer dip will indicate if any of your cells need equalization.
I agree with MEX if you are saying that your voltage is holding up under load. Not sure how these battery monitoring systems determine SOC but you need to verify SOC independent of you monitoring system if voltage is holding up normally.
Dick
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
