jrnymn7
Apr 29, 2015Explorer
In my experience, with my four 6v GC-2's, it takes several days for a good surface charge to dissipate on its own. Checking resting OCV an hour, or even a day later will give a higher than actual reading. Moreover, higher top charge voltages (15+V) result in lower resting/ocv readings, even though SG readings improve.
There seems to be a sweet spot, where both SG and OCV's max/equalize out... in my case, in the 14.6-14.8Vabs (TC) range. So I find it best to do a good top/desulfation charge, in the 15+V range, followed by a "normal" 14.6-8v Abs charge. I notice this with EQ'ing, as well. The resulting individual OCV's go crazy, but then level/equalize out, once followed by a normal charge cycle.
The OP's % SOC monitor is clearly not reliable... SOC cannot change at the flick of a monitor switch. And no, checking OCV cannot be done while under ANY load, or it's simply not an OCV... OPEN CIRCUIT means just that. And the same load will have a different peukert effect at a different SOC. So, for a simple, basic indication of when to charge, OCV may be fine, but for trouble shooting, it is very unreliable.
